I've mostly seen 4mv across the bias headers but I think that's too high. I generally set it to where it just starts to increase the idle current like this:
http://www.bcae1.com/temp/ausettingbias.swf
I tested the 47k resistors, they are ok.
All trim potentiometer now works, but I have another problem.
If I move the two driver boards in the picture slightly, the BIAS goes up and down. Same problem with both boards.
The other two work fine.
I thought the pin header has bad connection to the circuit board. I resoldered everything but the problem persists. Sometimes the LED's dont light up when I move the board too.
I think I have no choice but to lay patch cables?
Do you have another idea?
Best regards.
Best regards.
- General Interest
- Car Audio
- JL Audio 300/4 BIAS
