JL 500/1 component identification
Old 3rd June 2020, 12:42 PM   #1
randy0050 is offline randy0050  United States
randy0050's Avatar
Default JL 500/1 component identification
JL 500/1 PCB 100005 Rev 10
Amp had low volume and muddy audio, then went out completely
RCA input read short. I need help identifying this part.
Itís in front of the supply capacitors
File Type: jpeg 41B32173-C99B-458B-B70F-D3F0F537DF78.jpeg (921.5 KB, 53 views)
Old 3rd June 2020, 12:59 PM   #2
Perry Babin is offline Perry Babin  United States
Zener diode. I've seen both 5.6 and 6.8v there. Either will work.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 4th June 2020, 11:00 PM   #3
randy0050's Avatar
Thank you.
I changed diode and started checking voltages on 10 pin connector near +- inputs and got to pin 4 , then blew changed diode again and small pop sound emitted from test speaker . when pin 4 probed for voltage.
1. 5v
2. -14.9v
3. 13.7v
Low power input selected and gain set lowest position
Old 4th June 2020, 11:09 PM   #4
I think you likely shorted one of the 13v pins to pin 4. The diode has a series resistor to prevent excess current. The only other connection to it, as far as I know, is the LM324.
Old 5th June 2020, 01:50 AM   #5
randy0050's Avatar
So the resistor to the diode you believe is shorted? My eyesight is bad enough so could you direct me to the area of that resistor?
Also D611 and D612 are measuring short across each of them. I lifted D612 and it’s not faulty
Old 5th June 2020, 02:15 AM   #6
It's virtually impossible that the current limiting resistor is shorted.
Where are D611 and D612?
Old 5th June 2020, 07:28 AM   #7
randy0050's Avatar
I was praying it was muting component that Iíve read about in similar posts here. I still havenít lifted it because my voltages werenít similar enough
File Type: jpg 539A22EA-B251-46E1-9539-A260DAE8CB4D.jpg (690.3 KB, 33 views)
Old 29th June 2020, 09:33 PM   #8
randy0050's Avatar
The leg with the white (corrosion?) connects with the zener that keeps blowing. Is the white indication of it being bad?
Also d611 and d612 both read shorted in circuit but read good out of board
File Type: jpg 739D8640-6DE4-4A83-9E47-D68BDD78E145.jpg (925.8 KB, 17 views)
Old 29th June 2020, 11:36 PM   #9
Are you referring to the white paint on the transformer?
Old 30th June 2020, 02:28 AM   #10
randy0050's Avatar
Is it paint? I just noticed it and thought it was from heat or bad connection.
The diode traces back to pin 9 which is negative input for pin 8,
JL 500/1 component identificationHide this!Advertise here!
Help with component identification DArends Car Audio 4 10th April 2020 03:47 PM
Component identification mnhiphop101 Car Audio 7 14th March 2020 06:42 PM
Component identification mnhiphop101 Car Audio 2 9th November 2019 04:34 PM
Component identification Blckdggb Car Audio 0 9th November 2019 03:50 PM
Component Identification Spax Parts 5 6th May 2009 04:53 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
