Damaged Outputs. Looking for A1294... Anybody have replacement. I cant find them at mouser..
A Achim1409 Member Joined 2018 2020-05-29 2:57 pm #1 2020-05-29 2:57 pm #1 Damaged Outputs. Looking for A1294... Anybody have replacement. I cant find them at mouser.. ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2020-05-29 3:00 pm #2 2020-05-29 3:00 pm #2 FJA4213 is typically a good general replacement output for class B amps. ••• More options Share A Achim1409 Member Joined 2018 2020-05-29 3:50 pm #3 2020-05-29 3:50 pm #3 Its a class g/h with bias pot. ••• More options Share A Achim1409 Member Joined 2018 2020-05-29 4:06 pm #4 2020-05-29 4:06 pm #4 Same problem with the A1859A do you have also an alternative? ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2020-05-29 6:43 pm #5 2020-05-29 6:43 pm #5 That one is still available. For drivers in non-switching amps, I use the MJE15030/MJE15031 (complementary pair). It's only rated for 150v but I doubt that you have more than 150v across the rails in that amp. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link
