Orion Hcca5000.1D SPL
Old 4th May 2020, 12:28 AM   #1
bl4ckw1d0w is offline bl4ckw1d0w  United States
Default Orion Hcca5000.1D SPL
The power supply drive section uses A1023 and C1027 drivers which I need to replace and don't have. I do have the 1220/2690 pair and the bd139/140 pair and and abundance of others.
Which would be suitable replacements for these? Normally I would just experiment but seeing as parts for this amp are not cheap I want to reduce my chances of failing.
Old 4th May 2020, 12:30 AM   #2
Perry Babin is offline Perry Babin  United States
The 139/140 are the most common drivers used as subs.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 4th May 2020, 12:32 AM   #3
Thanks Perry. I wanted some peace of mind before I tackle this one :-D
Old 4th May 2020, 04:49 AM   #4
So I have a question for you Perry.
In the thread located Sound stream XXX-4000D repair help
You mentioned the power supply failing while the vehicle is being started and remote voltage is being applied.
Is the Orion 5000.1d spl similar in design to which you speak of? If so how can fix this or atleast give me a direction to go in.
This has happened to me twice with this amp and ive been scratching my head for a year on what the heck ive done wrong. You've made me realize that the last two times ive done it i have had my doors open and lights on in the vehicle without the vehicle running and the stereo off and working on something in the vehicle. Go to start the vehicle and the amp starts to draw current when the amp is told to turn on. I am assuming now because the battery voltage was low.
Old 4th May 2020, 06:47 AM   #5
The problem happened when the amp remote was powered by a source that went directly to battery voltage and didn't switch off when the engine was being started. Is that what you had?
Old 4th May 2020, 09:46 AM   #6
What i think may have happened is the engine was still cranking when the remote switched on. The unit switches off when turned over but its like a timed delay when it senses the engine being cranked. Not staying off the entire duration while the engine is being turned over with a weak battery.
Old 4th May 2020, 09:56 AM   #7
I can do more investigating after work.
Old 5th May 2020, 09:02 PM   #8
I found my answer in the smps page of the tutorial. Anyways how do i fool this amp into full or half duty cycles to help check the drive waves?
Old 5th May 2020, 09:06 PM   #9
Lower the 12v supply voltage. #31 on the PSTS page.
Old 5th September 2020, 09:21 PM   #10
That sawooth on pin 5 doesnt look right. Would this indicate the timing capacitor has drifted out of tolerance? The power supply is operating at 20 khz to 21khz seems a tad low.
File Type: jpg 15993405399415244851943002579158.jpg (1,009.0 KB, 31 views)
Fluke Scopemeter 105b 100MHZ | Weller WE1010NA 70watt | Dell E1100E-SO 12v (x4 in parallel) | Hot Air station
Orion Hcca5000.1D SPLHide this!Advertise here!
Orion 425 1st gen. nor1168 Car Audio 5 23rd October 2014 07:05 PM
orion acebaker Car Audio 0 19th February 2013 05:47 PM
Orion 280 gx mike49504 Car Audio 10 31st January 2010 04:24 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
Need Help With Orion 600 Amp!!!! Shades710 Car Audio 1 20th July 2004 09:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
