Unknow mosfet
Hi, i have on JL 300/2 4x irf540 and 4x unknow mosfet, somepeople know this mosfet? I don't found info about this device...
I have changed all r-channel mosfet, but i have this situation on power supply mosfet, drain pin (see picture).
The amplifier work normally, but after 5 min. The square wave is unstable and i hear the strange sound from power supply ( i think from toroid)
If you play music at a fairly high level, does the amp do this?
i have played low volume music, i must try with high volume.
Does it produce music normally when the instability starts?
i don't know, let you know.
i have misured also square wave on SG3525 output, is clean, but when instability start (change frequency), also this square wave is unstable. can be sg3525 broken?
