Vintage Kenwood KRC-747 Pin connection
Did it have a din connector like this?
Hi, thanks for suggestion. My unit is without the connector and so I rebulding the cable following service manual.... but I did'nt understand some connection.
Attach Service manual.
My question is:
- page 17: what means CD EJECT (pin 4)
- page 17: Pin 5 - IGN
- page 17: Pin 12 - Backup
- page 17: Pin 14 - Power Cont.
- page 17: where is remote?
wGtSIphnh2eTQAAAABJRU5ErkJggg==
Dropbox - Kenwood KRC-747D - HA1034.pdf - Simplify your life
Best regards
My question is:
Best regards
Are you removing the connector on the back of the radio because you don't have the wiring harness? If so, have you tried locating one?
Ign = +12V switched
Backup = +12V battery (unswitched for memory)
Power cont = remote
CD eject would be used when connecting a slave CD player
Hi, I already open it.
The Clarion 985MX seems different from 985MX k2 about the two external connector.
985MX have one connector with 5 pin seems for CD and 13 pin connector for amp.
I would like to understand what power amplifier I may connect it or better what are the pin of 13pins to use as line out.
Luca
