This one is strange, everything seems to be working, even proper current draw. It came out of protection and had full clean audio.
The amplifier starts up like all these do, draws currents then starts, draws 1amp at idle, yet the red protection light is on.
Regulated, rail present. No excessive current.
This is the same voltage latter as the previous amplifier I believe.
Some help.with this is issue would be welcome.
If you have all operating voltages and audio the amp is not in protection.
Either the Green LED has failed or the mute1 signal from the microcontroller has not been asserted.
Determine if LED1 is good. Monitor the DC voltage from power ground to R72-100kΩ(opposite side of Q30's base) through power up. Do the same with R53-100kΩ.
IC15
1) 10.39
2) 1.095
3) .458
4) .006
5) .001
6) 5.147
7) .911
8) 12.97
9) 0.00
10) 0.00
11) 13.45
12) .023
13) 36.75
14) 36.75
15) 51.89
16) 36.73
12) .023
13) 48.00
14) 47.98
15) 62.49
16) 47.97
I noticed the last 4 changed from 36. To 48 after I restarted the unit on both ic's
1) 10.39
2) 1.095
3) .458
4) .006
5) .001
6) 5.147
7) .911
8) 12.97
9) 0.00
10) 0.00
11) 13.45
12) .023
13) 36.75
14) 36.75
15) 51.89
16) 36.73
12) .023
13) 48.00
14) 47.98
15) 62.49
16) 47.97
Lift, in pairs D16,D24 and D17,D25 . You may need to have all four diodes to allow the 10.3 Vdc on Pins 2 of IC14 and IC15 to reassert allowing the IC's to come out of CSD (Current Shutdown).
Check the voltages around Q28-2N7002 and Q19-BC817. Also, look at the Vdc on the anode of D14 and either side of R49-1KΩ. There may be a failed transistor or diode in circuit,
When lifted d16,d24 ic15 pin 2 had it's 10.2vdc on it but when I lifted d17,d25 IC14 pin 2 only had 5.3vdc on it.
R49 has 13.3v and .043vdc.
D14 has 3.332 and 2.785vdc.
Amplifier stayed in a protection.
I also noticed that r24 stated to smoke? They both measure 10.1ohms and have +-17.86vdc on them.
Ok, so I left it powered up for awhile longer and the current did drop. R23, and r24 is burning up. I changed them. So did r84, r85, and q17, q18 is getting hot as well. There is only +-10.5vdc. After I shut it down and powered it back up the +-18.3vdc was back? And the resistors and transistors didn't seem to get hot. I have 90.vdc of rail on the side I did not change the ic on, the other side I changed is jumping around fr 50-63-71-43-ect .....the heating of those components seems to have stopped for now that the regulated is back to the +-18.59vdc.
- General Interest
- Car Audio
- Kicker 46cxa18001 protection issue.
