Rockford Fosgate T40001BD
Yes those voltages are with remote applied.
Without remote and amp still powered up:
1= 3.02v
2= 1.71v
3= 17.00v
4= 0v
5= 4.96v
6= 4.96v
7= 0.00
8= 2.40v
9= 2.70v
10= 1.40v
11= 1.40v
12= 0.0
13= Goes up and down between 0.66v to 1.11v
14= 1.2v
I just noticed the thermal light lights up along with the power and protect. In both scenarios with and without remote.
Arite, 95% of the demons were beat out when I replaced the 339. Remote worked again, thermal light went out, came out of protect. I stopped here for today, I have some work to complete on the thermistors as I had these jumpered to the board (seemingly I don’t have the originals on the MESHA thermal pads) and a couple other ends to tie up due to the troubleshooting process, hopefully I can have this done tomorrow and I get to test it out. Will let you know how it goes.
Arite, I got the back together powered up and did some audio tracing with the scope as I didn’t have audio on the output. I replaced all op amps TL072s, in the pre amp section and I got some progress. I have audio at the output with the master/slave switch set to slave. With the switch in either master or single I don’t get any audio output.
With no signal connected I have a 25hz signal at the output.
I rechecked the PWM A+B and the triangle wave, all are present.
I cleaned the switches but this didn’t help.
Any of you guys ever saw this? And/or could help me proceed?
Are the values for all four gangs on the potentiometer the same 20k value? I’m seeing the schematic has “20k,100k”
Physically it’s stamped “C20k” on the housing, I haven’t removed it from the circuit to verify.
