From R473 to the rca shields I bet tradings in the mega ohms and from R473 to the main ground also get readings in the mega ohms .
I will lift one side of that resistor and see if it changes anything
Lifting the resistor does nothing still 22 ohms from rca shields to ground terminal
Increase the value of that resistor.
One problem is could create is that a regulated power supply with an isolated secondary (except for this resistor) and no optical coupling, the regulation may become less stable, especially with no grounded signal source plugged in. It may or may not be a problem in this amp.
- General Interest
- Car Audio
- Orion 12500.1DSSPLX
