Good morning,
First time working on an Audison amp... I can't seem to pull a part number from any of the 6 power supply transistors. I'd think IRF3205 would be fine???
Thanks in advance.
Thanks in advance.
You can use lower value gate resistors. It will stress the drivers a bit more but it's not generally a problem.
It's odd that they used 10 ohm with those originals.
Measure the resistance from the emitters of the drivers to the pad for the gate of the FETs. Do you read only 10 ohms?
- General Interest
- Car Audio
- Audison LRx
