Hertz hp1d full rebuild
Thread Tools
Old 4th December 2019, 06:41 PM   #1
Lenin89 is offline Lenin89  Bulgaria
Default Hertz hp1d full rebuild
Full rebuild.
I've already removed all the FETS in the PS section and the Output section.
All dead.
Output driver board for the class D is still in place as I have to fix the PS section first.
I've checked the gate drive in the PS just before the gate resistors (as this ones also have to be replaced).
I don't think this is normal. Two of the banks driving one of the transformers look shifted upwards. The other one looks normal. Pictures attached. So I think i will have to rebuild also the PS board - i think it is the buffer driver transistors.
Old 4th December 2019, 08:22 PM   #2
Kaboom...
I have to look up somewhere for schematics to rebuild this. I was extremely careful while removing the SMD transistor but still....
Old 4th December 2019, 09:15 PM   #3
Okay, this is some generic KA7500 board design but i think it's pretty much almost the same as mine.
As i can't read the markings on the burnt transistors, logical thinking brings me to the conclusion that they were marked as BE RN = BCX55**, a 1Amp NPN transistor in SOT-89 ?
Old 4th December 2019, 09:47 PM   #4
ultra is offline ultra
ultra's Avatar
Can you take a photo of the underside of the board close to the speaker connector ?
Old 4th December 2019, 09:48 PM   #5
Yes I can, no problem - but it's going to be tomorrow.
Old 4th December 2019, 10:08 PM   #6
Perry Babin is offline Perry Babin  United States
2SB1260 and 2SD1898?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 5th December 2019, 08:04 AM   #7
As much as I could see the markings these transistors are BE RN and DK RG which I believe are: BCX55-16 and BCX52-16 and these I can order from Farnell.
2SB1260 and 2SD1898 are impossible to find in my region.
Old 5th December 2019, 12:29 PM   #8
Look at the connections for the transistors. The PNP transistors will have their collectors directly connected to ground. Use whatever you can get but make sure you have the NPN and PNP in the correct locations.
Old 5th December 2019, 09:58 PM   #9
ultra's Avatar
Will you take the photo ?
Old 6th December 2019, 06:35 AM   #10
Yes of course, but i'm still driving home. I promise when I come back to my place I will.
Hertz hp1d full rebuildHide this!Advertise here!
Thread Tools
Hertz HP1D diagram kajox Car Audio 9 23rd June 2020 01:26 PM
Hertz HP1D problems ViNzZz Car Audio 64 15th May 2019 01:09 PM
Hertz HP1D missing transistor luigidedom Car Audio 3 7th August 2014 03:34 PM
DIY 50 Hertz and below Sub djkiwi Subwoofers 26 2nd May 2012 03:52 PM
Hertz hsk 165 zumbo02 Car Audio 0 4th February 2012 01:19 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
