Old school Soundstream Tarantula
Old school Soundstream Tarantula Please consider donating to help us continue to serve you.
Old 3rd December 2019, 12:35 AM   #1
caraudioguy2100 is offline caraudioguy2100
Default Old school Soundstream Tarantula
Not sure of the model number .
I got this amp in for repair and when I try to increase the input voltage
(Turn the volume up on head unit ) the amp will protect on me and as soon as I lower the volume on head unit it will power back up .
Does this sound like a problem in the preamp section ?
Or wondering where I should start checking
File Type: jpg D385E6DE-8898-4377-880C-11710A362002.jpg (855.0 KB, 32 views)
Old 3rd December 2019, 12:40 AM   #2
Perry Babin is offline Perry Babin  United States
Does it do it without a load?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 3rd December 2019, 12:55 AM   #3
No
Old 3rd December 2019, 01:11 AM   #4
Let me check a few things and Iíll get back to you since the amp has no output now
Old 3rd December 2019, 01:31 AM   #5
If it only does it with a load, it's generally due to an emitter resistor out of tolerance, with a bad connection or a leaky protection transistor.
When it gets audio again, drive only one channel with a load to see which channel is causing the problem.
Old 3rd December 2019, 04:56 AM   #6
I found an LM34DZ which appears to be a temperature sensor
Leg 1 is the +5 volts
Leg 2 is the output
Leg 3 is the ground
According to the data sheet I found
Here are the measurements I get
Leg 1 to Leg 2: 30.0 ohms
Leg 1 to leg 3: 16.1 ohms
Leg 2 to leg 3: 16.4 ohms
Does this appear to be defective or is it suppose to measure like this ?
Old 3rd December 2019, 05:19 AM   #7
If you heat/cool it do you get a varying output?
Those resistances do seem low.
Old 3rd December 2019, 05:34 AM   #8
Heating or cooling it makes no change at all .
I will go through the rest of the amp and see if I find anything else bad .
After going through the amp I will order a new one and take readings off it .
I think the amp is stuck in protection now since itís not producing rail or regulated voltages
Old 3rd December 2019, 06:58 AM   #9
Ok something in the circuit is causing the temp sensor to read bad .
There are caps that show they are shorted along with multiple transistors reading shorted.
I will have to check the entire circuit to figure out which part is causing This issue
Old school Soundstream TarantulaHide this!Advertise here!
Soundstream Tarantula TRA1400.2 Formas Car Audio 6 31st March 2019 08:52 AM
Soundstream Tarantula Old School Jason Smith 616 Car Audio 12 4th March 2018 06:52 AM
Old School Soundstream Tarantula Jason Smith 616 Car Audio 6 2nd March 2017 11:16 PM
Soundstream tarantula 6x9 RubberSalt Car Audio 6 14th November 2011 07:23 PM
Soundstream Tarantula 1400.2 lt1superman Car Audio 3 3rd July 2009 02:18 AM
Copyright ©1999-2019 diyAudio
