Scope settings 10 us 5volts/div 2 0.1 if caps in series across gate and source here is what I get
C caraudioguy2100 Member Joined 2010 2019-12-10 8:20 am #21 2019-12-10 8:20 am #21 Scope settings 10 us 5volts/div 2 0.1 if caps in series across gate and source here is what I get Attachments B7BC1709-FA28-4EF0-B28E-B4A75860C6D3.jpg 789.5 KB · Views: 55 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-12-10 8:29 am #22 2019-12-10 8:29 am #22 Does the PNP driver have its collector directly connected to ground? Source, the 3rd leg? ••• More options Share C caraudioguy2100 Member Joined 2010 2019-12-10 8:34 am #23 2019-12-10 8:34 am #23 Yes the collector (middle leg) connects directly to ground And yes 3rd leg of the fet source leg ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-12-10 8:40 am #24 2019-12-10 8:40 am #24 Is the signal the same on both banks? Is the signal on the base of the two drivers a clean square wave like this was before loading? ••• More options Share C caraudioguy2100 Member Joined 2010 2019-12-10 8:53 am #25 2019-12-10 8:53 am #25 Yes both banks are the same . And the waveform on the drivers is good like before loading it. ••• More options Share C caraudioguy2100 Member Joined 2010 2019-12-10 10:34 am #26 2019-12-10 10:34 am #26 Replaced the chipset (494) and replaced the drivers again . The drive is good all the way down to the gate resistor with it loaded then at the gate resistor the drive gets goofy like in the previous posts . ••• More options Share C caraudioguy2100 Member Joined 2010 2019-12-10 11:09 am #27 2019-12-10 11:09 am #27 Here is what I get if I load it with a fet instead of caps . Scope settings 10us 5 volts /div Attachments 8DF84AA5-4B47-49C8-8474-9868B43E3C02.jpg 731.9 KB · Views: 44 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-12-10 4:10 pm #28 2019-12-10 4:10 pm #28 That's bad. What value are the pulldown resistors between the base of the drivers and the collector of the PNP driver (ground)? If it's open, install something between a 1k and a 330 ohm on each driver pair to see if it helps. ••• More options Share C caraudioguy2100 Member Joined 2010 2019-12-10 6:46 pm #29 2019-12-10 6:46 pm #29 Would the 2n4401 and 4403 work in the power supply as drivers replacing the c945 and A733 ? The drivers I put it tested good but we’re used so wondering if I might have a bad driver somewhere ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-12-10 7:05 pm #30 2019-12-10 7:05 pm #30 The drivers are likely OK. What are the pulldown resistor values? ••• More options Share C caraudioguy2100 Member Joined 2010 2019-12-10 7:18 pm #31 2019-12-10 7:18 pm #31 There are 56 ohm resistors connected to the drains and 470 ohm resistors connected to the source legs ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-12-10 7:23 pm #32 2019-12-10 7:23 pm #32 With no power applied, measure the resistance between pin 9/10 and pin 7 of the 494. What do you read on those two? ••• More options Share C caraudioguy2100 Member Joined 2010 2019-12-10 7:27 pm #33 2019-12-10 7:27 pm #33 Resistance from pin 9 to pin 10:0.946k Resistance from pin 9 to pin 7:0.474k Resistance from pin 10 to pin 7:0.471k ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-12-10 8:12 pm #34 2019-12-10 8:12 pm #34 Do you see a 470 ohm resistor connected across the points that are reading 470 ohms? ••• More options Share C caraudioguy2100 Member Joined 2010 2019-12-10 8:38 pm #35 2019-12-10 8:38 pm #35 Yes ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-12-10 9:01 pm #36 2019-12-10 9:01 pm #36 What does the drive signal look like on pins 9/10 of the 494? ••• More options Share C caraudioguy2100 Member Joined 2010 2019-12-10 9:18 pm #37 2019-12-10 9:18 pm #37 Scope is 10us 5 volts/div Here is what I get on pins 9/10 they look the same Attachments 1D9FA1A7-894D-47FA-A5AF-62BC97AC20C2.jpg 707.7 KB · Views: 31 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-12-11 12:27 am #38 2019-12-11 12:27 am #38 If you see the same signal at the base of the drivers, the drivers are bad. ••• More options Share C caraudioguy2100 Member Joined 2010 2019-12-11 4:04 am #39 2019-12-11 4:04 am #39 Would the 2n4401/4403 work to replace the originals C945 and A733? ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-12-11 4:08 am #40 2019-12-11 4:08 am #40 You can use virtually anything. The PS drivers are not really critical. The 4401/4403 will be OK. The pin configuration is different so you'll have to twist the base and emitter leads. ••• More options Share Prev 1 2 3 4 Next First Prev 2 of 4 Go to page Go Next Last Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home General Interest Car Audio Audio Art 260.6XE Top Bottom
