Where can i get Parts for this amp? Kicker says i would Need to ship it to them for $150. The part i need Is probably only 5-15$. It is the speaker terminal. It cracked and so the set screw won’t tighten down. Any help will be appreciated.
If no one can tell me where to source parts. Would someone be able to recommend a alternate fix? I’m not interested in sending this out to pay for a factory repair which cost more than the amp is worth. (That’s like paying $1000 for repair on a car valued at $700 - — when all it needs is a $60 alternator)
I was Thinking of removing the terminal and maybe soldering an 8 gauge wire in its place.
Is the connection point that solders to the board a four-pin connection?
I see that the setscrew is on the opposite side of the original, not sure how the terminal protrudes from the amp if it is usable.
I do have an over-seas connection to most any part but there is typically an MOQ that has to be met.
