I also had a similar problem.Hi,anyone here know the actual working rail voltage of the MM4000.1D?Cap rated at 120V itself.Got a on-hand unit with blown transient voltage suppressor,PK6E250A,on one rail.
Also duty cycle on the DC-DC PWM (TL494 based) is around 33%,is that normal?
Most of the time, due to lack of replacement, I simply eliminated the transient suppressor and the amplifier works perfectly even without that diode.
Could someone explain to me what these suppressor diodes are for?
this is the board...What output driver board does this amp use?
2 IRS21844S and only TL072 and LM211.
LM293 is on the main board.
Most of the 3S-tech type amps are unregulated so they run at 50% duty cycle.
Does the rail voltage or the pulse width vary when you adjust the 12v supply input voltage?
I don't have a variable power supply but the supply voltage is rated at 12.4V.
Also,got 2 output fets were blown.....so i assume i should remove all remaining fets for further testing,on the rail voltage and also the gate voltage?
- General Interest
- Car Audio
- Autotek MM4000.1D rail voltage
