Phoenix Gold MS-2125 no rail voltage
Old 16th November 2019, 12:52 AM   #11
Perry Babin is offline Perry Babin  United States
Measure the DC voltage across all 4 of those diodes.
What's the DC voltage on all 3 terminals of the transistor that you replaced?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 16th November 2019, 03:09 AM   #12
Chopperbuilder is offline Chopperbuilder  United States
The DC voltage on the three legs of the transistor are:
1. +10.8v
2. +10.7v
3. +10.0v
As to the diodes will you please point out which 4 you are referring to?
Multimeter: Blue Point - Model: MT586B / Oscilloscope: Leader - Model: LBO-524 / Power Supply: 12v-15v adj 115 amp
Old 16th November 2019, 03:23 AM   #13
Sorry. The 4 red LEDs that are not lit.
What's the supply voltage across the B+ and ground terminals of the amp?
Post the DC voltage on all pins of one of the PS driver ICs.
Old 16th November 2019, 03:55 AM   #14
See attached photo for DC voltage readings across the 4 LED's.
The supply voltage across the B+ and ground terminals of the amp is +10.8v
DC voltage of PS driver IC:
1. +0.001v
2. +2.15v
3. +0.20v
4. +0.497v
5. +2.022v
6. +3.623v
7. +1.942v
8. +4.81v
9. +6.19v
10. +0.008v
11. +4.05v
12. +0.001
13. +10.77v
14. +4.05v
15. +10.77v
16. +5.06v
Old 16th November 2019, 04:05 AM   #15
Why is it so low? Increase it to about 12v.
What's the DC voltage on the pins of either of the opto-couplers?
Old 16th November 2019, 04:35 AM   #16
I'm not sure what is pulling it down. There is almost a 2v drop between what the power supply meter is showing and the reading at the amp terminals. I turned it up voltage at the amp terminals is now 12.2v
I'm guessing you are refer to one of the opto-couplers that are to the right and left of the PS driver ICs...
DC Voltage on the opto-coupler on the right in the photo in #14:
1. -2.1v drops very rapidly
2. -2.1v drops very rapidly
3. -0.002v
4. +2.52v
5. +5.06v
6. +3.19v
Old 16th November 2019, 05:11 AM   #17
Measure directly across 1/2 and then across 4/5/
Old 16th November 2019, 05:42 AM   #18
The DC voltage across 1/2 is +1.10v, 4/5 is +2.54v
Old 16th November 2019, 06:02 AM   #19
Do both read the same?
If you increase the supply voltage (at the amp) to about 13.5v, does the voltage at 1/2 top out higher or does it remain about the same?
Old 16th November 2019, 06:20 AM   #20
I'm not sure what you are asking me "Do both read the same?"
I only able to increase the supply voltage at the amp up to 13v. The voltage across 1/2 remains the same regardless if supply voltage is 12v or 13v.
Phoenix Gold MS-2125 no rail voltageHide this!Advertise here!
Steg K24 Vs Phoenix Gold 2125 ms gianca78 Solid State 2 26th August 2019 08:44 AM
Help me please x Phoenix Gold ms 2125 lokatos Car Audio 7 4th June 2015 04:06 AM
Phoenix Gold ms 2125 "Disaster" Help !!!! Fenice Car Audio 47 4th November 2010 04:57 AM
Phoenix Gold 2125...Help lele73golf Car Audio 0 23rd September 2010 06:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
