Solar amplifier
Solar amplifier
Old 20th October 2019, 09:54 PM   #1
shanecapetown is offline shanecapetown  South Africa
Default Solar amplifier
Hi guys im currently busy with a solar class d amplifier I got the amp with the power supply fets blown replaced it and powered up the amp i got class d switch on output fets and amp is playing but there is a high pitch sound on the speaker no fets heating up just the AG AND DK ON DRIVER BOARD BUT IT'S NOT BURNING HOT JUST LOW is that normal?
Old 21st October 2019, 12:54 AM   #2
Perry Babin is offline Perry Babin  United States
Photos of the main and driver board?
Does it sound like this:
http://www.bcae1.com/temp/cooleditmixedoscillator01.wav
Are you hearing it through a subwoofer or are you using a full range speaker for testing?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 21st October 2019, 03:44 PM   #3
It does make that sound yes I'm using a full range speaker to test
Old 21st October 2019, 07:01 PM   #4
That's normal for an amp that doesn't have synchronization between the power supply and output stage oscillators.
There isn't much you can do about it. It's generally not bad enough to be heard with subwoofers, especially when they're mounted in the trunk.
Old 21st October 2019, 08:54 PM   #5
Ok thank u sorry is it normal for the Dk & AG transistors to warm up
Old 21st October 2019, 10:52 PM   #6
Old 22nd October 2019, 01:52 AM   #7
Yes.
On amps like this, you have to confirm that ALL output transistors have drive. It's possible for some of the drive circuits to fail and the amp still work (or appear to work) normally.
Old 22nd October 2019, 06:02 AM   #8
Yes.
Hi Perry all outputs gets drive . So this amp is good. To go
Solar amplifierHide this!Advertise here!
Solar Shoeboombox mmmalmberg Chip Amps 11 7th July 2015 11:31 PM
It just keeps getting better for Solar Cells fas42 Everything Else 137 9th May 2015 06:39 PM
Solar eclipse Wavebourn The Lounge 12 25th May 2012 01:17 AM
solar maximum scott17 Everything Else 16 1st February 2012 11:54 PM
Copyright ©1999-2019 diyAudio
