Positive power supply rail at a different potential than negative rail?
Old 17th October 2019, 06:32 PM   #61
The Lord Flashheart is offline The Lord Flashheart  United Kingdom
Then its probably fine.
Any idea where the strange voltages on Q101 and Q202 could be coming from?
Old 17th October 2019, 06:40 PM   #62
Osvaldo de Banfield is online now Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
The most common causes of such a kind of failures are resistors (Open or altered, usually in the increasing resistance direction), transistor or diodes. Also a severe leak from a electrolytic cap. but less common.
Check R210, R212, R214, D201 and Q202/3.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 17th October 2019, 08:09 PM   #63
They all check out fine Osvalsdo, thank you for your continuing help on this by way.
Old 18th October 2019, 12:18 PM   #64
Ok. Let's try again, shorting C209. This will cause the output stage to be quasi inoperative, and in class B, so big dosis of distortion will appear, but let us know if this action tend to normalize the DC operating points of the stage.
Old 18th October 2019, 02:13 PM   #65
I forgot to remember, that all this test, be done with the limited current supply, to prevent future damages.
Keep us posted.
Old 21st October 2019, 02:16 PM   #66
And? No news, good news?
Positive power supply rail at a different potential than negative rail?Hide this!Advertise here!
Adding single rail amp to split rail amp power supply jdelange Power Supplies 2 1st August 2016 08:46 AM
Power supply negative rail Valie Power Supplies 5 22nd February 2016 05:53 PM
Wanted: Op-amp with single supply, 32V or more, and rail-rail capability akis Power Supplies 3 13th November 2010 01:53 PM
I need a negative supply rail--but how? wally.gribbles Tubes / Valves 5 18th February 2008 07:36 PM
Small voltage deviation at positive and negative rail 2Bak Chip Amps 1 14th December 2003 06:42 PM
Copyright ©1999-2019 diyAudio
