No DC maybe less than 1/2 a volt no audio. The amp isn't drawing any current. Like its not fully power up. Draws about 40 amps on initial power up then stays at about 1.5-2.0 amps. Usually they are around 7-10 amps when idling.
I didn't measure the heat, I already removed it. Heating up my iron now for replacement. It's not a big deal to change, at least I can rule it out after replacement.
Changing the IC got rid of the supply voltage on all pins except the ones that are suppose to have the 6 volts according to the schematic. It also returned a square wave to pins 2 and 5, also 3 still has a square wave.
All the rail switchers have 141vdc on the drains, and the audio FET's have no voltage on gate, drain, or source. I'm not sure if this is useful, thought I would mention it.
