Kicker CXA300.1 No rail, regulated or gate drive.
Old 8th October 2019, 06:24 AM   #11
rhempz01 is offline rhempz01  United States
the aot460 replacement mosfet?
Old 10th October 2019, 02:26 AM   #12
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
IRFB3306
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Old 10th October 2019, 07:58 PM   #13
great thanks.
Old 11th October 2019, 12:08 AM   #14
ok so i replaced the power supply mosfets and the driver.
No audio.
replaced the output transistors and the ird20957s and a top side 100uf 16v cap exploded. c13
2 10r resistors burned up.
r143, r141
Old 11th October 2019, 03:07 AM   #15
PapaZBill's Avatar
C13 is the filter cap for the +12VE supply for the Vcc pin 11 IC4-IRS20957. R142 & R143-10 ohm are in line with C13. R141 is a 2 ohm resistor.
Is it possible you have a solder bridge or the IRS20957 was installed backwards?Check C93-457/C and D31-ESD1
This is an unusual failure.
Arthur C. Clarke
Old 14th October 2019, 12:11 AM   #16
ok so ordered all parts that i will need on these repairs.
I thought i was doing something wrong, maybe pulling the incorrect resistor for the protection.
the red protection led stays lit.
but the 494 will produce drive.
Old 21st October 2019, 04:50 PM   #17
c93 reads a short across it in circuit. is it 5uf? how many volts? 50-100v?
Old 21st October 2019, 05:23 PM   #18
PapaZBill's Avatar
C93 is a 4.7uF, not sure what the voltage rating is but the cap is on the 12v line for IC4-pin 11 of the IRS20957-VCC. Check IC4,C95. The 12v is coming from Q17-BCP56, ZD8-13v zener. C13-100uF 16v may have shorted.
Arthur C. Clarke
Old 25th October 2019, 03:51 AM   #19
c95 reads short. value?
Old 25th October 2019, 05:13 PM   #20
so i replaced the capacitors that read a short with some from another unit for now. amplifier still is in protection with the resistor r68. The issue is i put new outputs in the amp and it was working came out of protection, had audio, until q19 shorts everytime? the resistors are all good?
Kicker CXA300.1 No rail, regulated or gate drive.Hide this!Advertise here!
Kicker cxa300.1 ic3 identification. rhempz01 Car Audio 25 27th August 2019 03:11 PM
Kicker CXA300.4 No power rhempz01 Car Audio 3 26th March 2019 08:36 PM
Kicker cxa300.1 help please jayjs730 Car Audio 3 10th February 2019 03:15 AM
Kicker ZX1500.1 gate drive problem mbates14 Car Audio 1 5th June 2013 11:57 PM
Kicker ZX1500.1 without gate drive. Randy62 Car Audio 7 29th May 2013 06:47 PM
Copyright ©1999-2019 diyAudio
