MTX Thunder 4122
MTX Thunder 4122
Old 21st September 2019, 06:48 PM   #1
jkrokenberger is offline jkrokenberger  United States
Default MTX Thunder 4122
Hi there, I have an MTX Thunder 4122 that powers up and plays. It has a problem though, D93 has shorted and burned a trace to ground. D93 is in the input section of the amp. It is a simpler amp with only a hi/lo/full pass switch and gain control. Any help would be appreciated.
Old 21st September 2019, 06:52 PM   #2
Perry Babin is offline Perry Babin  United States
Photo?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 21st September 2019, 07:09 PM   #3
The diode, D93 has the anode tied to RCA ground and the cathode to power ground. The trace from cathode to power ground is burned, diode is measuring shorted. The amp plays fine as it is now, I can get photos in a little while. I am suspecting the amp had the main ground wire lose connection at one time, could that cause the problem?
Old 21st September 2019, 07:11 PM   #4
That's right. Remove and don't reinstall the diode. There should be a parallel 1k resistor and another identical diode with a reverse connection. Those should be checked. Without a photo, I'm assuming that this amp is like many of the older MTX amps.
Old 21st September 2019, 07:18 PM   #5
There is a parallel 1k resistor but D93 is the only diode in that area. This amp is a surface mount version of the Pleitz design Thunder 250x. While not identical it is very similar.
So, remove the diode and repair the trace then?
Old 21st September 2019, 07:34 PM   #6
If the anode was connected to the RCA jacks, it's a later version where the one that could burn when the amp lost ground had already been omitted. What probably happened was 12v was allowed to contact the RCA shields. The trace will be need to be repaired. I'd replace the diode in the later design with only one diode.
Old 21st September 2019, 07:42 PM   #7
Thank you sir. I will do that and see how it goes. I will report back.
MTX Thunder 4122Hide this!Advertise here!
MTX Thunder 942 legion2710 Car Audio 1 22nd May 2016 01:49 AM
MTX Thunder 4122 No sound Exbass17 Car Audio 10 15th November 2014 02:11 AM
MTX Thunder 895 mike49504 Car Audio 3 17th June 2014 03:27 AM
MTX Thunder 302 Dr Zeus Car Audio 1 18th December 2011 06:10 AM
Help STK 4122 mute circuit artvipinosa Solid State 0 2nd November 2011 03:13 PM
Copyright ©1999-2019 diyAudio
