Rockford T2500 - 1BD
Good morning Perry, returned with this amplifier, when I install the output mosfet the signal is square wave becomes a noise in the gate of the mosfet, at some point I pressed the card and moved it from side to side and I got oscillation I've verified track by track and connection by connection and I do not find that it makes the amplifier not oscillate, definitely something is missing from the BD card but I can not find that it can be in the diagram that I sent you if you look at it you can tell me where to check the signal arrives well until the resistance before lm5110 the bd mute voltage drops to 0 and when it worked in a moment I had 7v, another thing is that the yellow LED also flashes quickly, for me it is something broken on the board but I can not find that it can be, give me ideas to review please
Perry do you think the problem is the BD card? the strange thing is that I had oscillation in a moment and now only toggleA and B arrive until the resistances, if I disconnect B of the diode d2017 I have a square wave both at the entrance and exit of the lm5110, the only thing that I have not changed on the BD card is the HC74
If you mean q201 and q 200 that are mosfet, both remove them and probe them out of the circuit and try them well, I exchanged them but nothing else the same problem that confuses me is that without the mosfet I have oscillation and with the capacitors that you indicated to me that I will also have oscillation I thought it was false contact but nothing I have solved and measured continuity and everything seems to be correct I have reviewed the welding in the entire bd card and in the area of ​​transistor drivers and diodes transformers but nothing I still suspect that there is something that is not and that was at the moment I moved the card
If you want to open a new one with what I currently have and the tests I have already done, because I already tested without rail voltage and closing the feedback cycle and I have a square wave in the output transistors, I introduced the rail voltage again without the bridge of the feedback and I get a wave signal with the 0.01 microfarad capacitors as soon as I put the mosfet the square wave does not reach the mosfet and is only clean before the resistances that are before 5110 and the yellow LED is constantly blinking
