Linear power 2502iq offset problems
Old 15th September 2019, 04:42 PM   #11
Perry Babin is offline Perry Babin  United States
If you cannot find the problem, post a photo of the board.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 15th September 2019, 10:50 PM   #12
maurosubito is offline maurosubito
I'm searching, all semiconductors have been inverted with those in the other channel and the problem is in the initial channel.
capacitors are all new.
I have to remove all the diodes and resistors and check with patience.
I have no other ideas
Old 20th September 2019, 04:09 AM   #13
Problem seems solved.
I removed and checked all the passive components in the audio section without finding anything out of tolerance.
I reassembled and re-sold everything and now the amplifier works well, the 500mv dc offset has gone.
now I have a 30mv dc offset in one channel and 70mv dc offset in the other, but the problem is 6 mps8599 transistors (3 for each channel)
if I invert the transistors the offset moves to the other channel, I have to find some mpsa56 or something equivalent to replace them
Old 20th September 2019, 04:11 AM   #14
Didn't you try that (first post) and the offset remained n the same channel?
Old 20th September 2019, 04:20 AM   #15
before I had an offset of 500mv dc in a channel, after removing and replacing all the passive components that offset is gone.
I had tried to invert all the semiconductors but an offset of 500mv remained on the same channel
my problem was those 500mv dc always on that channel that disappeared after removing and re-welding all the passive components
Linear power 2502iq offset problemsHide this!Advertise here!
LInear Power 2502IQ clayton Car Audio 30 17th January 2015 04:12 PM
Can D.C. Offset cause non linear distortion Mooly Solid State 12 6th February 2014 07:05 AM
Phase Linear 700 level control offset problem smallies Solid State 0 14th February 2011 05:37 PM
Problems with DC offset Buhl Chip Amps 32 6th February 2006 06:51 AM
Offset problems, again sangram Chip Amps 21 12th January 2006 02:08 PM
Copyright ©1999-2019 diyAudio
