American Bass VFL 110.1 protection after relay
Old 12th September 2019, 05:49 PM   #31
barber02 is offline barber02  United States
The trigger level doesn’t clean up the drive signal in any of the modes other than make it worse if you go too far in one direction or the other.
Adjusting the hold off to about 4.6us does clean it up a little bit but not much.
File Type: jpg CEE61A6A-56F4-47D2-817F-1D2F16AC71B0.jpg (883.9 KB, 14 views)
Old 13th September 2019, 03:12 PM   #32
I pulled the output mosfets from this amp and it no longer goes into protection. Iím still reading 1.5 vdc at the speaker terminals.
This is the drive signal on the low side and high drives. I was wondering if this looks normal before I go any further with this. The drive signal looks the same at the pads of the mosfets as it does coming out of the driver board measured before it reaches the motherboard.
Probe is 1x, scope is set to 5v/div, 5us
Thanks for your input.
David
File Type: jpg A5F49615-009B-4D72-884D-07EE4A6FE985.jpg (980.4 KB, 10 views)
File Type: jpg E4A430BE-3754-41EB-A630-A8C621224F1F.jpg (694.3 KB, 9 views)
Old 13th September 2019, 03:46 PM   #33
twilliar is offline twilliar  United States
I would revisit the drive card (do you get excessive hot spots when powered on), check the pull-down and gate resistors and double-check the output transistors. Not many ways for DC to get to the output if the output transistors are being driven correctly.
Old 13th September 2019, 04:07 PM   #34
Perry Babin is offline Perry Babin  United States
You initially stated that the amp had DC on it's output but the waveforms you've posted show nothing that would produce significant DC offset and the amp is remaining on long enough for you to get the images of the waveforms. What has changed?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 13th September 2019, 05:18 PM   #35
All I did was remove the output mosfets.
Then I powered up the amp to look at the wave forms and that’s the pictures I posted today.
As for yesterday...
When I was taking the scope images before I removed the outputs all I did was lower the voltage to the amp from 14 volts to 10 volts. The DC to the output would slowly rise to 3 volts before the protection circuit kicked in. That would usually take about a minute. At 14 volts the DC would rise in a matter of seconds.
David
Old 13th September 2019, 07:09 PM   #36
Is there any DC voltage on the RCA shields?
American Bass VFL 110.1 protection after relayHide this!Advertise here!
American Bass VFL 500.1 Deadly Sones Car Audio 36 20th October 2014 01:04 AM
American bass megael9 Car Audio 19 20th May 2014 12:12 AM
American bass protection mode Austin texans Introductions 1 15th October 2013 02:39 PM
American Bass sq300 Jailbreak Car Audio 1 22nd August 2013 06:49 PM
American Bass VFL-500.1 mike49504 Car Audio 5 7th January 2011 11:07 PM
Copyright ©1999-2019 diyAudio
