American Bass VFL 110.1 protection after relay
Old 12th September 2019, 05:06 PM   #11
barber02 is offline barber02  United States
When I try to view the wave form on my mains powered scope all I see is a bunch of scattered dots. When I zoom in with time division I can see some resemblance of the wave form but it is still just a bunch of dots. No defined lines. I am grounding the probe to the negative terminal of the amplifier.
I am measuring the rail voltage with my fluke 12 grounded to the negative terminal of the amplifier.
David
Old 12th September 2019, 05:15 PM   #12
Well. In the repair tutorial you stated you get 46 vdc on the cathode side of D23 so now I’m thinking the reading I got is normal for this amp.
David
Old 12th September 2019, 05:20 PM   #13
D23 readings.
File Type: jpg B84A3E5C-6ACE-4F7D-A886-EF718B09E742.jpg (1,020.4 KB, 14 views)
File Type: jpg 56798E87-5AFA-44DE-8BFA-2958F6A414BB.jpg (995.5 KB, 14 views)
Old 12th September 2019, 05:22 PM   #14
Perry Babin is offline Perry Babin  United States
Only dots? Is your scope damaged?
Using the scope in differential mode will allow a much different setting (5v/div) than you'd need in normal mode.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 12th September 2019, 05:27 PM   #15
These are the readings on D21.
David
File Type: jpg 453B33E1-0BC6-4948-96CF-3043B4B07EF7.jpg (895.3 KB, 13 views)
File Type: jpg 1A95595D-9236-4E6E-A177-BC82AD2F28D7.jpg (874.9 KB, 12 views)
Old 12th September 2019, 05:31 PM   #16
This is what is see on my scope when I probe the tab of the mosfets on the high side.
File Type: jpg D07DBD3E-866F-40AC-81DE-C0154F7CD13A.jpg (892.5 KB, 14 views)
Old 12th September 2019, 05:33 PM   #17
The tab of the high-side FETs is DC voltage.
Old 12th September 2019, 05:53 PM   #18
No matter which leg I probe, if the is a drive wave there then I get that image on the scope. If I get on a leg with DC voltage the the trace deflects off the screen.
On a side note. I notice that R256 (measures 100 ohm) gets really hot and R262 (measures 1k ohm) is staying stone cold. Is that normal?
David.
Old 12th September 2019, 05:57 PM   #19
This is the drive on the tab of the mosfets in the power supply so the scope appears to work. Im not sure what is going on.
File Type: jpg 7E3C538B-D138-4EE9-B5BB-2CE0D2005935.jpg (881.5 KB, 6 views)
Old 12th September 2019, 06:02 PM   #20
Is your probe set to 10x?
Isn't that a storage scope? If so, what if you switch to that mode
American Bass VFL 110.1 protection after relayHide this!Advertise here!
American Bass VFL 500.1 Deadly Sones Car Audio 36 20th October 2014 02:04 AM
American bass megael9 Car Audio 19 20th May 2014 01:12 AM
American bass protection mode Austin texans Introductions 1 15th October 2013 03:39 PM
American Bass sq300 Jailbreak Car Audio 1 22nd August 2013 07:49 PM
American Bass VFL-500.1 mike49504 Car Audio 5 8th January 2011 12:07 AM
Copyright ©1999-2019 diyAudio
