Help in finding diode for Lanzar MinX3000D
Old 10th September 2019, 04:28 PM   #1
imraneesa is offline imraneesa
Default Help in finding diode for Lanzar MinX3000D
Hi all
I am attaching the driver board image for Lanzar MinX3000D amplifier. D1 is shorted. I would like to know the value of it. It may be zener diode. Thank you.
Old 10th September 2019, 05:45 PM   #2
Perry Babin is offline Perry Babin  United States
Are either of its pads connected to any pins of any of the ICs
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 10th September 2019, 06:36 PM   #3
It is not connected to any ic.
Old 10th September 2019, 07:03 PM   #4
if you look up iraud9.pdf online, there will be a reference design for this IC. It may be similar.
https://www.infineon.com/dgdl/irauda...53569aee022bff
Old 10th September 2019, 07:39 PM   #5
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Is C12 in parallel to this diode?
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 10th September 2019, 07:57 PM   #6
Yes c12 is parallel to the diode. I removed D2 to test and it conducted at 5.1v. So I tried with 5.1 at d1 but no oscillations and amp goes into protect.
Old 10th September 2019, 08:02 PM   #7
If C12 is in parallel to the diode, and the cap is 16VW, then a 15V zener will sufice. IR211x are mosfet drivers and need about 12V for proper job. 5V zener is too low.
Old 11th September 2019, 05:28 PM   #8
there is some difference in the circuit it is not matching. i replaced it with 5.1v zener and no oscillations, i fear if u2 and u3 are bad. i scrape out the epoxy on top of ic and i found 05623 on it. i am guessing if it is nand gate. can you help me more in this. Thank you sir,
Old 11th September 2019, 05:32 PM   #9
Are there similarities?
I'm working blind and only have the information that you provided.
Old 11th September 2019, 05:52 PM   #10
It is looking different.
Help in finding diode for Lanzar MinX3000DHide this!Advertise here!
Need help finding a substitute for Sanyo SV-31 thermal compensator diode partyface86 Solid State 3 23rd January 2016 07:57 PM
Mosfet with inverted parallel diode or zener diode nonprof Car Audio 4 23rd October 2015 03:18 AM
Need help finding a diode Mass Car Audio Class D 1 23rd December 2008 03:50 AM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
Need help finding replacement diode BrianDonegan Parts 2 4th April 2005 04:21 PM
Copyright ©1999-2019 diyAudio
