HFI1500D Power Fets Blow After Remote is Disconnected
Old 6th September 2019, 08:37 AM   #21
Perry Babin is offline Perry Babin  United States
Where are you placing the black meter probe?
Does the voltage on pin 12 drop from 12v to 0v IMMEDIATELY when remote is removed.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 6th September 2019, 08:41 AM   #22
djeokis is offline djeokis
Ground. Terminal Post of the Amp.
Old 6th September 2019, 08:54 AM   #23
Voltage is15V, then when i remove remote, drops to 0.35v after that starts to drop slower... On pin 12
Old 6th September 2019, 09:00 AM   #24
Are you using your meter or does your scope have a digital readout?
Old 6th September 2019, 09:15 AM   #25
I have both connected, using only one lead. for the positive lead.
Old 6th September 2019, 09:20 AM   #26
Going to leave this as To be continued, until i receive parts, i believe i just fried the IC, shorting it by accident... Once i get it, lets hope it fixes my issue... I'll keep you post it... I really appreciate the time and help. Many Thanks.
Old 6th September 2019, 02:26 PM   #27
Did you slip?
How are you accessing the pins? Right-angle probe or driver board connected to the main board via wire jumpers?
Only buy parts from authorized distributors.
Old 13th September 2019, 11:16 PM   #28
Hello. no, i shorted pins 7 and 8.. burned out Q2...Replaced IC 7500 and the Q2, now the green light turns on, now going to check the if it has negative pulse on pins 3 and 4. added jumper cables to board, to avoid slips or shorts ( will Try )
Old 15th September 2019, 01:19 AM   #29
UPDATE : Got the amp to work... Thank you for you help Perry, you guided me to the location that i ignored, assuming that it was working properly. Thread can be closed.
Thank you.
HFI1500D Power Fets Blow After Remote is DisconnectedHide this!Advertise here!
Hfi1500d help Colorado8804 Class D 6 23rd June 2019 06:49 AM
NAD fuses, slow blow or fast blow? AllCaster Solid State 3 25th October 2009 06:11 PM
Remote mounting fets Safe_Cracker Class D 1 14th February 2009 07:47 AM
DC offset after power disconnected Pooley Chip Amps 10 25th September 2008 11:33 PM
Just had a power cap blow! azira Parts 19 24th June 2004 09:28 AM
Copyright ©1999-2019 diyAudio
