HFI1500D Power Fets Blow After Remote is Disconnected
Old 6th September 2019, 07:03 AM   #11
djeokis is offline djeokis
yes, 47ohms
Old 6th September 2019, 07:18 AM   #12
Perry Babin is offline Perry Babin  United States
Did you confirm that the drive signals were identical on both banks of PS FETs?
This will be more reliable if the FET locations are loaded.
Did you try removing the B+ and remote together to see if the FETs would survive?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 6th September 2019, 07:23 AM   #13
Yes, both signals are identical. If i disconnect both, remote and B+ the amp survives, if i only disconnect the remote, with the power supply i have, it's only burning one FET at a time, if take it to my vehicle, it blows all 5 FETs at once when removing the remote.
Old 6th September 2019, 07:36 AM   #14
You'll have to remove the PS FETs and clean the solder pads.
Monitor the DC voltage on terminals 3 and 4 of the PS control IC carefully when the remote is removed. Set the scope to 2ms and about 1v/div. When remote is removed, does the voltage on either terminal go negative?
Old 6th September 2019, 07:56 AM   #15
Removed FETs and cleaned pads / B+ 15v / Terminal 3 = 15V / Terminal 4= 14.39V /
None went negative after removing the remote signal.
Old 6th September 2019, 07:59 AM   #16
3 and 4 can't be at those voltages.
You need to monitor with your scope. The meter isn't likely to be fast enough to catch any negative pulse.
Old 6th September 2019, 08:02 AM   #17
Pins 3 and 4 from IC 7500? ... i was measuring terminal post 3 and 4 from the module.
Old 6th September 2019, 08:09 AM   #18
I measured Pins 3 and 4 / Pin 3 has no pulse. / Pin 4 shows a negative pulse after removing remote.
Old 6th September 2019, 08:21 AM   #19
It's probably being used for a softstart and that can cause the problem you're having.
Is the voltage on pin 12 dropping to 0v IMMEDIATELY when remote is removed?
Old 6th September 2019, 08:29 AM   #20
If that were the case, IC gone bad? Measured pin 12, voltage drops to 0.35v then starts to drop down when remote is removed.
HFI1500D Power Fets Blow After Remote is DisconnectedHide this!Advertise here!
Hfi1500d help Colorado8804 Class D 6 23rd June 2019 06:49 AM
NAD fuses, slow blow or fast blow? AllCaster Solid State 3 25th October 2009 06:11 PM
Remote mounting fets Safe_Cracker Class D 1 14th February 2009 07:47 AM
DC offset after power disconnected Pooley Chip Amps 10 25th September 2008 11:33 PM
Just had a power cap blow! azira Parts 19 24th June 2004 09:28 AM
Copyright ©1999-2019 diyAudio
