TARAMPS HD8000
TARAMPS HD8000
Old 10th September 2019, 04:00 PM   #11
Albis2985 is offline Albis2985  Panama
Good morning David, yesterday I realized what you told me and one of the output inductors had a false contact now the amplifier is not going to protect, thanks for your help, I just need to try a battery bank to see how it behaves because With the source I have it is not so good to test and yesterday the test began to flash the blue LED that if I remember in the manual it indicates that the battery is low, correct me if I am wrong
Old 10th September 2019, 04:43 PM   #12
barber02 is offline barber02  United States
I had one do the same thing to me a few weeks back with good supply voltage. It had low output. Mine turned out to be a shorted diode mounted close to one of the output transistors. This one was blinking, not completely going on and off, but blinking none the less even at idle.
Now having said all of that, if the blue LED dims under a heavy load then supply voltage/current could be the issue.
David
Old 10th September 2019, 04:54 PM   #13
Well, in my case, it flashes after increasing the volume and consumption, but the amplifier still sounds only that the LED flashes, I will test with a battery bank and tell you how it went.
Old 16th September 2019, 04:50 PM   #14
Good morning David, the test with the amplifier was satisfactory, it was the coil of the output with false contact that made the amplifier protect itself thanks for your support.
TARAMPS HD8000Hide this!Advertise here!
Taramps hd8000. 1 output section help. rhempz01 Car Audio 10 24th May 2019 12:56 AM
DSPIC33F1010 for 14.2KW TARAMPS nonprof Car Audio 2 4th July 2018 12:54 AM
Taramps 50K dbr Jason Smith 616 Car Audio 0 25th February 2018 12:41 AM
Taramps HD6500 jlind54 Car Audio 27 10th April 2017 05:33 PM
taramps ta2700 megael9 Car Audio 25 29th August 2011 04:00 PM
Copyright ©1999-2019 diyAudio
