Rockford Fosgate Punch P1000-1bd
Old 14th September 2019, 10:18 AM   #31
rhempz01 is offline rhempz01  United States
OK I'll preform that test. Also all the filter caps test at 2800uF I believe they should be at least 3100uF. I don't know if that is enough to make a difference?
Old 15th September 2019, 05:04 PM   #32
ok so switching all the cards to know good cards .
No audio at speaker terminal.
Audio is present on the pin on the bd card.
what or were else could stop the audio
Old 15th September 2019, 06:23 PM   #33
Perry Babin is offline Perry Babin  United States
For testing, the filter caps are good enough.
Do you have rail-rail oscillation?
Are you saying that you swapped in known good driver boards and the amp still won't produce audio?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 20th September 2019, 10:51 PM   #34
Here is what i have at present. New filter caps. lm5110 new. Dc voltage match.
regulators are all at the correct output voltages.
i have a 40hrz signal at the pin of the bd card, it adjusts with the gain pot.
none of the ic in the daughter cards seem to heat up faster than the others.
-2.54vdc at the speaker terminal.
No audio.
No rail at the outputs
Old 20th September 2019, 11:42 PM   #35
No rail voltage or no rail-rail oscillation at the outputs?
Old 21st September 2019, 12:06 PM   #36
No
Q2009
1.) .043v
2.) 14.27-22.35v jumps up to down
3.) .001v
Old 21st September 2019, 02:53 PM   #37
audio is back now after cleaning the pads and resoldering the 4H11G recifiers down.
Old 21st September 2019, 03:23 PM   #38
I think you're referring to the SMD transistors that are used as voltage regulators. The part number is MJD44H11G.
The large blue resistor R9 sometimes breaks loose from the board and causes intermittent problems.
Rockford Fosgate Punch P1000-1bdHide this!Advertise here!
Rockford Fosgate p1000-1BD. rhempz01 Car Audio 53 27th August 2019 02:48 PM
Rockford Fosgate punch p1000-1BD eldan94 Car Audio 12 9th May 2019 08:13 AM
Rockford Fosgate P1000-1bd RiLoWa Car Audio 9 29th July 2017 03:46 PM
Rockford Fosgate p1000-1bd no output geekybasshead1998 Car Audio 30 20th April 2016 12:08 AM
Rockford Fosgate P1000 Amp Wont Power On? stockz Car Audio 3 13th January 2013 10:23 PM
Copyright ©1999-2019 diyAudio
