I'm working on a Hifonics HFI3000D, So far I've replaced the power supply fets ( IRFP064N ) and all 47 ohm gate resistors. The resistors i ordered were a different type of resistor that was in it I'll post a pic. I have also removed all of the( IRF9640 ) in the output side 3 of them were bad. Should i replace all the gate resistors or just te ones out of tolerance. After that is there anything else i should check before putting it back together and testing it?
I replaced all power supply fets and gate resistors and all 8 of the IRF9640 in the output along with the gate resistors and all the pulldown resistors. I put the amp back in the case and clamped everything down and attempted to turn it on with a15 amp fuse inline and the redlight will come on then goes green then pops the fuse.
- General Interest
- Car Audio
- Hifonics HFI3000D
