Soundigital evo SD12000 v2
Old 14th August 2019, 01:58 AM   #1
Ekacboon is offline Ekacboon
Default Soundigital evo SD12000 v2
Friend of mine just bought this used
Went with him and it was hooked up in car and working
after we got back to the warehouse
I took the cover off to see one of the fets legs were missing/melted.
saw that they shave the chips and re engrave with codes
H3
I saw on here someone said the H3 is CSD18502
was able to locate at mouser CSD18502KCS
is this correct and should i look for anything else out of place before soldering in the replacement?
thanks for the help.
I feel bad for him I kind of gave him the green light
looks legit go ahead to buy it..
Old 14th August 2019, 03:49 AM   #2
barber02 is offline barber02
If the mosfet is still good I’d try to repair the legs of the transistor with wire leads from 1/4 resistor at a minimum, I think the wire leads of a 1 watt resistor would be better and solder them on.
The alternative is to replace the mosfet with a new one, but doing that you need to replace all of the power supply mosfets on that side.
As for the part number. That one should do the job.
As for anything else to check, definitely the gate resistors to make sure they in spec and the board and vias for that mosfet for damage. Looks pretty cooked.
Old 14th August 2019, 01:17 PM   #3
ultra is offline ultra
ultra's Avatar
I confirm H3 is NOT CSD18502.
Old 14th August 2019, 09:19 PM   #4
laluns is offline laluns  South Africa
you can use the CDS18052 as I have seen SD use them on the older 12k amps. Mainly the amps that came in a silver case. Also another thing to take note the 12k amps that have the CDS18052 uses SI8244Cb chips to drive the output fets.
Soundigital evo SD12000 v2Hide this!Advertise here!
Help for soundigital transistors maurosubito Car Audio 2 14th May 2018 09:07 AM
SounDigital SD8000.1D? ThyDntWntMusic Car Audio 1 11th January 2018 04:35 AM
SounDigital SD16KD-SMD Deadly Sones Car Audio 51 24th February 2015 01:39 AM
Soundigital 8K brandes.cm Car Audio 36 5th January 2013 11:28 PM
Soundigital 16kd rodd1two Car Audio 6 19th February 2012 03:54 PM
Copyright ©1999-2019 diyAudio
