Hifonics Colossus X3
Old 8th October 2019, 03:29 PM   #21
Perry Babin is offline Perry Babin  United States
The transformer is soldered in the board. Did you power it up and find a problem that you believe to be transformer related?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 8th October 2019, 04:04 PM   #22
Achim1409 is offline Achim1409  Germany
yes, i removed the transformer because of intermittend short. I insulated the windings, but forgot, how the windings was connected togheter to the board. I tried some options.. if i connect center taps to center board, i draws high current. The other option, is the center tap to the upper connection on bord, then it works normal, but if i measure voltage on the rectifiers, i have 0V at the inner connection, ( the inner connecteion between the to rectifiers is connected to the center conection on the bord). Ground probe at B-
2Ch. DSO, Multimeter, Hot Air Station, Soldering Irons,
12V Server Supply, L-C-R Tester, Component tester
Old 8th October 2019, 04:25 PM   #23
I'm not sure I understand the confusion. The windings typically alternate (notice gold and violet in the image below). The two in the center are typically connected together.
You could have a problem with a shorted transformer. I've only worked on one amp like this and it had 2 bad transformers that required insulation be added to the windings to save them.
Old 8th October 2019, 04:26 PM   #24
yes, i expected the same as on your picture...so i will check next time aggain...
Old 9th October 2019, 05:11 PM   #25
So, i repaired the transformer with a special resin. My problem is still, that i dont know, how to bound the windings together, because i mixed during repair. On the transformer i have to secondary windings. The end of this windings i bound together as center tap. Then i have the aux winding for the op voltage. I bound them also to the center tap, and the open ends, as it was before to the diodes. I have voltage, but the fets on the side of this transformer slowly heats up, and i have no green light, as same no audio came out.
For shure i made something wrong with bounding this windings.
Old 9th October 2019, 05:26 PM   #26
If it's not drawing excessive current (peg out the power supply), I think you have it right.
I'm assuming that the aux windings have the same ratio and go to the same secondary power supply.
Old 10th October 2019, 09:44 AM   #27
I just checked aggain, i think its correct. I measure on the rectifiers for the op amps, 30V DC, but ist dropping slowly to 20V. On the OP amps i have 0V...so i have to check, whats wrong there.
Old 10th October 2019, 09:57 AM   #28
In some amps with regulated power supplies, the pulse width initially goes to near 50% then drops back as the target rail voltage is reached. That may explain why the aux supply goes high then drops and stabilizes.
Old 10th October 2019, 02:15 PM   #29
Can I parallel bzx55c15 to get 1watt?
Old 10th October 2019, 04:11 PM   #30
Technically, yes but if you're doing this for a paying customer, order the right parts.
Hifonics Colossus X3Hide this!Advertise here!
Hifonics Colossus VI Jason Smith 616 Car Audio 17 15th May 2019 08:31 PM
E0B-011-40 Hifonics Colossus XX bl4ckw1d0w Car Audio 2 21st August 2018 05:06 PM
Anyone here with an Hifonics Colossus XX ? Costin1812 Car Audio 17 16th January 2014 11:09 AM
hifonics colossus amp mike49504 Car Audio 1 7th June 2007 07:40 PM
hifonics colossus xi mike49504 Car Audio 1 7th October 2006 05:33 PM
Copyright ©1999-2019 diyAudio
