XX-Goliath 5kW issues
Old 8th August 2019, 05:46 PM   #21
Perry Babin is offline Perry Babin  United States
Blown driver ICs can pass current from any terminal to any other terminal.
The path through to the gate pads was no different than any other terminal if the IC shorted internally.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 12th September 2019, 03:35 PM   #22
BumpinYota is offline BumpinYota  United States
I just wanted to update this thread now that I have some more time:
The main board works perfectly with the driver card removed, with no DC on the speaker outputs and it is fully reassembled sans the output fets. I replaced all 4 of the 21844s chips as per your tutorial they die at the drop of a hat.
I have a few questions though:
1. What are L2 and L4?
2. The capacitors on the bootstrap circuits are supposed to be what value?
3. Any ideas how to make a connection on pin 14 of my far left 21844s chip since that trace broke off?
4. Can I advertise your repair guide a bit to generate some more funds for you?
5. How are you doing?
Old 12th September 2019, 04:32 PM   #23
You may have to pull the corresponding inductors from the other ICs and measure them.
If you're referring to the high-side supply caps, they can vary quite a bit. I've seen values from about 3.3uF to about about 10uF. It's best to measure the value of the others in your amp if one has failed.
There is no connection to pin 14 of the 21844s.
For anything not amp related, you can email me.
XX-Goliath 5kW issuesHide this!Advertise here!
G.A.S Goliath Cambe Analog Line Level 27 19th August 2016 12:02 PM
hifonics goliath luigidedom Car Audio 1 24th September 2014 01:50 PM
Hifonics goliath mike49504 Car Audio 14 10th March 2010 04:26 AM
David and Goliath Bgt Class D 7 1st October 2005 08:02 PM
Amplifier Goliath! viktor1986 Solid State 11 27th June 2005 09:15 PM
Copyright ©1999-2019 diyAudio
