IC3 is an MP18021 gate driver. R105 will be open also.
R105 is a 4.7 ohm. Check to be sure there are no shorted outputs-AOT412's and filter Capacitors-2200uF/50v.
If nothing else, before replacing the AOT460's and after replacing the 18021 and R105, remove R68-4.7k ohm and check the Drive to the Gate resistors.
If all looks good replace mosfets and you should be good to go!
Did you check the AOT412's out of circuit? They may appear to be shorted in circuit, due to a latch condition of IC4-IRS20957
Have you been able to reestablish the power supply rails? If so, assuming the gate resistors 4.7 ohm are in tolerance, replace the AOT412's and check for drive. etc.
Look for U7-2068 at the input. With signal, check to see if you have output at U7-Pin 7.
If you have signal and you can manipulate it with the gain control move forward to IC6-2068 Pins 3 & 4 near PWM.
If you don't have signal move backward to U6-2068 Pins 7 & 5,and U5,U4 etc to the RCA's if necessary.
How hot are the outputs? This may be normal. If they are not shorting you should be okay. I think there is an interruption in the signal path.
- General Interest
- Car Audio
- Kicker cxa300.1 ic3 identification.
