Settings
100hz on top of E301
50hz on top of E301
100hz on top of E301 probe set to 10x
50hz on top of E301 probe set to 10x
50hz on top of E301
You can leave them disconnected. Do you see any signal on the base of the two transistors?
If the output of the IC has signal and that signal drives the two transistors, they should have signal on their collectors.
If the emitter of the transistors is at -5v, connect a wire jumper between the collector and emitter of Q310.
Q310
Settings
Base
Emitter
Collector
Pic of Q310? The number is partially obscured so I am just making sure.
Settings
Base
Emitter
Collector
- General Interest
- Car Audio
- Alpine PDX1.1000 powers on, no audio (IR2010s HELP)
