dB vs Hz
dB vs Hz
Old 15th July 2019, 06:41 PM   #11
Gioba is offline Gioba  Italy
Gioba's Avatar
Originally Posted by Aqeeb127 View Post
I want to build a enclosure that will give the highest spl number these woofers can do
I'm sorry, i cannot aid you in this case, but you can consider to double power of the sub for to gain +3dB.
And for SPL you can use a class D amp and get high power.
Old 16th July 2019, 04:57 PM   #12
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Duplicate thread here:
SPL Box
The OP apparently has an amp in the 1kW range and 12" woofers.
He wants to achieve the highest SPL that he possibly can for a local dB drag type contest. Fidelity is of no concern in these situations, only to register the highest number on the SPL meter. Most likely using a pulsed signal, not steady-state. Exciting a mode for huge one-note resonance is key to winning.
Tim
Old 16th July 2019, 04:59 PM   #13
Perry Babin is offline Perry Babin  United States
For one note with the highest gain, a bandpass enclosure may be the best (but not a simple) option.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 16th July 2019, 05:06 PM   #14
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Yes, I saw that crazy...
If it's raw SPL, I'd be much concerned in what's behind the speaker, the body of the car etc. Imagine how many losses from the holes and the pressure
( To OP: you must have problems, seriously. Calm down and search for quartets/quintets with violins, violas, cellos, pianos, harpsicord, harps, flutes etc in gardens, verandas )
Everything under and above heaven is in utter chaos
mare monstrum
dB vs HzHide this!Advertise here!
Copyright ©1999-2019 diyAudio
