lmao.. that's sort of what scared me... too cheap to be true, lol
So, something like these would be fine?
RioRand 100 MHz Oscilloscope Clip Probes with Accessory Kit (Pack of 2): Amazon.ca: Gateway
Then I just need to adjust them to the scope via the trim pot in the probe?
OK.... I'll order in a pair. Should be here next week.
Any ideas on this amp issue. At least it's not kicking in and out of protect until it pops now. With high power it shorted all 4 banks low side fets. also damaged one of the ICs, but I replaced them all again. On low power I get what I showed you on the fets.
Each time you go up, try all of the mechanical tests on the boards and inductors.
Look at the drive signals to see if anything changes. MAke sure that the drive to the FETs never goes above 20v (with reference to the source leg -- don't ground your scope to the negative rail).
You may want to read up on using your scope in differential mode. Tech Tips 8, item #8.
- General Interest
- Car Audio
- American Bass 1100.1
