Quantum Audio QB2000D component id
Old 25th June 2019, 06:18 PM   #11
cajones65 is offline cajones65  United States
I am not getting voltage across the emitter resistors. I have my ps set for 3amps and voltage drops to 7.3vdc.
Think it may be a good idea to pull the outputs and check the resistors that away?
Scope: Kenwood CS-1065, Meter: Fluke 87v, Hakko FX-8888D soldering station, 858D rework station. PS: 30v/10a variable
Old 25th June 2019, 06:22 PM   #12
Perry Babin is offline Perry Babin  United States
The voltage would be in the mv range. If the output stage is the problem, the current almost certainly has to be flowing through the output transistors.
If it's not clamped down, check the heating of the outputs to see if they're heating up.
A current limiting resistor typically works better than the limiter in a power supply.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 25th June 2019, 06:30 PM   #13
Problem must be in power supply, outputs are not heating up at all. I am getting 4.8 to 5 mv across the emitter resistors.
Some of the fets in the ps are heating up. I have been shutting off the power supply when the amps rise. Not giving it time to heat anything up.
Old 25th June 2019, 06:33 PM   #14
What work have you done to the power supply?
Sometimes letting it draw current for a few seconds lets components in the problem area heat up and can help with troubleshooting.
Have you clamped it to the heatsink and powered it up with no limiting to see if the current draw was simply inrush?
Old 25th June 2019, 06:40 PM   #15
I have not done any work in the power supply section. The only thing I have done is replaced a blown diode in the output section. I believe this to be the over current circuit.
I have not clamped it back in the heatsink. I will try that before I go any further.
Old 25th June 2019, 06:41 PM   #16
Also check the operating frequency.
Old 25th June 2019, 06:58 PM   #17
It is not an in rush issue. All transistors are clamped down. Amps go up and voltage drops. Have a power light and not a protection light. Fixing to pull her back out of the heatsink.
Old 25th June 2019, 07:00 PM   #18
Are you still limiting the current?
Old 25th June 2019, 07:05 PM   #19
No sir, well actually I have a 10 amp power supply and had the current wide open. Plus it is paralleled with another 12 amp power supply
Quantum Audio QB2000D component idHide this!Advertise here!
JL Audio 500/1 component help 86boy Car Audio 33 4th February 2014 04:29 PM
Quantum Audio QCA4000D S Merlington Car Audio 51 27th August 2013 12:14 PM
quantum audio qsa 1500d op amps missing voltage ivkata Car Audio 2 18th February 2013 06:27 AM
FS: ESX Quantum Q120.4 Steve Mantz (Zed Audio) Mobile Amplifer (4x120 @ 4 ohms/12V) omarmipi Swap Meet 1 2nd December 2010 10:31 PM
Copyright ©1999-2019 diyAudio
