Pin 8 and pin 5 are connected together via a 5 band resistor R227. Best I can discern is that it should a 12k ohm resistor 5 percent tolerance. In circuit it reads about 16k. I’m going to pull it and check it out of circuit.
Pin 8 connects to the high side FETs through a 7 ohm resistor R281 and then the trace continues on to a couple of at the gates of the high FETs (R237 and R235) at 27 ohms each on the last two high side FETs.
David
David
I pulled the J111 transistor that is identitfied as Q282 on the board and tested in my transistor tester and this is the result it gave me. Do you think this may be why my output section has no drive and is dead quite? I have positive and negative rail voltage but no drive.
I don’t have any in stock so I’ll have to order some.
- General Interest
- Car Audio
- Digital Design M1d
