Digital Design M1d
Digital Design M1d
Old 1st August 2019, 02:16 PM   #21
barber02 is offline barber02  United States
Hey Perry,
Sorry for the delayed response. I had a thunderstorm come through yesterday so I shut my lab down early.
The diode connects to pin 7
Old 1st August 2019, 03:14 PM   #22
Pin 8 and pin 5 are connected together via a 5 band resistor R227. Best I can discern is that it should a 12k ohm resistor 5 percent tolerance. In circuit it reads about 16k. I’m going to pull it and check it out of circuit.
Pin 8 connects to the high side FETs through a 7 ohm resistor R281 and then the trace continues on to a couple of at the gates of the high FETs (R237 and R235) at 27 ohms each on the last two high side FETs.
David
Old 1st August 2019, 03:42 PM   #23
That resistor reads 83.2k ohm out of circuit.
Old 1st August 2019, 04:53 PM   #24
Perry Babin is offline Perry Babin  United States
Did that solve the problem (assuming that the 12k resistor was the one that was far out of tolerance)?
I've requested more information on this type of amp from another tech. There is little chance but I have nothing solid to work with.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 1st August 2019, 05:45 PM   #25
No. Pin voltages are the same.
Old 14th August 2019, 12:20 AM   #26
I pulled the J111 transistor that is identitfied as Q282 on the board and tested in my transistor tester and this is the result it gave me. Do you think this may be why my output section has no drive and is dead quite? I have positive and negative rail voltage but no drive.
I donít have any in stock so Iíll have to order some.
File Type: jpg 66E8FFFD-122D-4976-80EB-E2357593F82C.jpg (821.4 KB, 19 views)
Old 14th August 2019, 12:37 AM   #27
I don't know what the tester is telling you. Typically, a jfet will read low resistance between the drain and source with a meter and will read as a diode in one direction between the gate and the other terminals.
Old 14th August 2019, 12:56 AM   #28
I know. I was a little confused as to the results myself.
Old 9th October 2019, 04:09 PM   #29
I forgot to follow up on this repair.
The faulty component was L5 in front of D34 and D23. It was open. Replaced the ceramic inductor and the amp produced audio again.
David
Digital Design M1dHide this!Advertise here!
Digital design megael9 Car Audio 70 5th August 2017 07:15 PM
Digital design megael9 Car Audio 28 22nd December 2014 01:32 AM
Software for digital crossovers design krzys Multi-Way 0 27th January 2012 01:55 PM
Looking for digital attenuator design..... Mark A. Gulbrandsen Pass Labs 3 8th June 2011 01:43 PM
Board Level Digital Design Bronze Digital Source 0 6th December 2003 07:50 PM
Copyright ©1999-2019 diyAudio
