Kicker CXA 1800.1 pulls high amps
Old 10th November 2019, 04:35 PM   #21
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
If the Hi level turn on circuit is correct, the High Current Draw must be caused by something in the Output section.
Check Outputs, IC14,15, Q101,102,201,202, All Capacitors surrounding the IRS209957 IC's. R39-10 ohm and C69-220uF/16v with an ohmmeter.
What is the current when the power supply mosfets are in place?
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Old 10th November 2019, 04:45 PM   #22
barber02 is offline barber02  United States
The component replacement that you wanted clarification on in post #20 were applied.
As far a current draw. When I power the amp up it pretty much maxes out my bench power supply at 40 amps and flickers rapidly between 30 and 40 amps as soon a I power it up.
I checked the power supply mosfets and the output mosfets out of circuit and they all test good.
I’ll check the components you mentioned in post 21 Monday when I get back to my shop. I am out of town this weekend.
Kicker CXA 1800.1 pulls high ampsHide this!Advertise here!
1625 Mono Block Tube Amps 55 WPC $1800 jonparkhurst Swap Meet 9 17th January 2015 08:42 PM
OLD SCHOOL KICKER AMPS HIPCHECK Swap Meet 0 20th March 2013 07:43 AM
Kicker kx1200.1 amps (2) cut out under load jimmyjames22 Car Audio 8 23rd May 2011 01:26 AM
Best place to get Kicker amps? eastman474 Car Audio 3 5th November 2009 08:33 PM
Kicker Amps skooter Car Audio 3 8th November 2007 04:53 AM
Copyright ©1999-2019 diyAudio
