Kicker cxa300.4 low audio issue
Old 15th June 2019, 05:25 PM   #1
rhempz01 is offline rhempz01  United States
Default Kicker cxa300.4 low audio issue
I now have a kicker cxa300.4 that has rail, and regulated voltage. Powers up fine, and draws @1 amp of current. Plays audio very low even at max gain. I been searching around for damaged components and can not seem to find the culprit. Some help would be most welcome.
Old 15th June 2019, 05:27 PM   #2
Topside of pcb
Old 15th June 2019, 05:28 PM   #3
Bottom side of pcb
Old 16th June 2019, 12:12 AM   #4
barber02 is offline barber02
On the bottom side of the PCB on the top edge of the board about in the middle of your tweezers I see what looks like a broken trace or bad solder joint.
Old 17th June 2019, 06:02 PM   #5
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
Possible muting issue.
First check if any DC voltage between Power & Speaker Ground. If so check resistance between same. If Open check for open traces and RP87-0 ohm resistor. You may recall previous threads I've brought this up Rhempz01. This is a very common issue.
If that's not it check the DC voltages at the PWM daughter board pins and post. Starting on either side of the board and label Pins 1 through 13.
The muting circuit uses a C945 JFET at the input to each channel. One by One remove Q19 through Q22 to see if the mute clears and isolates to one channel
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Kicker cxa300.4 low audio issueHide this!Advertise here!
Kicker CXA300.4 No power rhempz01 Car Audio 3 26th March 2019 07:36 PM
Kicker cxa300.4 audio jack problem amp 2 rhempz01 Car Audio 3 14th March 2019 01:32 AM
Kicker cxa300.1 help please jayjs730 Car Audio 3 10th February 2019 02:15 AM
Kicker CXA300.4 no audio troubleshooting help. rhempz01 Car Audio 19 4th November 2018 03:15 PM
Kicker CXA300-4 Won't power on. rhempz01 Car Audio 8 25th July 2018 07:08 PM
Copyright ©1999-2019 diyAudio
