Door speaker clearance issue
Old 13th June 2019, 06:50 PM   #11
barber02 is offline barber02
I was thinking the same thing as Perry. Mount the speakers to the back side of the spacer if you can. That will give you plenty of clearance. Otherwise you have to buy an aftermarket speaker spacer that is set up for that. You may be able to modify the current spacer to accept the speaker on the back side of the spacer versus the front of the spacer.
I think they are called inset spacers or something like that.
Old 14th June 2019, 02:17 PM   #12
Tweaked is offline Tweaked
I just found these, and think they might work. They are designed to be mounted onto but I could mount them in front of the speaker instead and that would prevent the door panel from pressing on the surround.
Amazon.com: dco Universal 1/2 Inch Plastic Depth Ring Adapter/Spacer for 6.5" Car Speakers: Automotive
Door speaker clearance issueHide this!Advertise here!
Looking for a Good Sliding Door track and door for Delco/Pioneer 12 disc cd changer wascapsfan Parts 0 24th June 2012 01:23 AM
front door speaker placement Dan2 Car Audio 16 12th September 2011 02:30 PM
Does speaker Qts matter in door installations? mda185 Car Audio 19 29th July 2009 07:59 PM
6.5 full range door speaker skooter Car Audio 0 21st November 2007 03:22 AM
Using a t-line speaker on a car door? ksl Multi-Way 7 30th August 2005 04:03 PM
Copyright ©1999-2019 diyAudio
