Capacitor value for tweeter protection with active crossover
Old 5th June 2019, 05:43 PM   #1
Chopperbuilder is offline Chopperbuilder  United States
Default Capacitor value for tweeter protection with active crossover
In the event something should ever fail in my system I would like to have a capacitor in place in series with my tweeter to protect it from receiving a full range of frequency. I have done a lot of research on this yet I haven't been able to find a definitive answer as to what capacitor value I should use for how I have my system set.
I'm using:
Audicontrol DM-810 - crossover set at 2600k Hz Linkwitz–Riley 24dB/octave slope.
A/D/S PX Concept tweeters 4 Ohm.
I have found a number of calculators on line but the ones for a single in series capacitor are for a 6 dB/octave slope. Those that I've found for a 24dB/octave slope are for building a passive crossover.
Anyone have any suggestions on what value capacitor I should use?
Multimeter: Blue Point - Model: MT586B / Oscilloscope: Leader - Model: LBO-524 / Power Supply: Modified computer 500 watt
Old 5th June 2019, 06:09 PM   #2
academia50 is offline academia50  Argentina
The value of the tweeter capacitor is chosen according to the crossover with the mid range, (overlap in Db) and depends on the frequency response and the sensitivity of both transducers, to achieve a reusable as flat as possible.
A typical value would be between 5 and 10 uF. for a crossing at 5000 hertz, but that does not say much, and make sure you have good isolation in volts, 100 volts minimum!
Old 5th June 2019, 06:21 PM   #3
Perry Babin is offline Perry Babin  United States
There is virtually nothing that could happen to cause the crossover to receive a full range signal. The benefit that you will get with an inline capacitor is blocking any DC from the tweeter if the amp fails.
I'm not sure what you meant by 2600kHz.
A single cap will only be 6dB but that will block DC. Any value capacitor will do that. Choose one that would be a bit below the crossover frequency of your electronic crossover for a 4 ohm tweeter.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 5th June 2019, 06:33 PM   #4
rayma is offline rayma  United States
Around 100uF bipolar will be ok for protection. Much smaller will affect the crossover response.
Old 5th June 2019, 06:39 PM   #5
The active crossover point for my mid range and tweeters is 2600 hertz. I initially chose a 17uF 100v capacitor for this but then I ran across an article talking about this subject saying that the dB/octave slope needs to be taken into account in determining the value of the capacitor: https://www.audiofrog.com/community/...ve-crossovers/
In fact the 24dB/octave slope, crossover point (2500 hertz) and tweeter resistance (4 Ohm) he was using in the article are almost identical to how I have my system set. He chose a 68uf 100v capacitor for this. With such a large value difference between the capacitor I have and the one he was using, it had me second guessing my choice. With further research I could find nothing to confirm or discredit using a 68uF capacitor as the correct capacitor for this application.
Old 5th June 2019, 06:49 PM   #6
The crossover point for my mid range and tweeters is 2600 hertz. I initially chose
Not really. The idea is for the high pass formed by the protection C with
the 4 ohm tweeter to be a decade lower than the actual crossover frequency,
2600Hz/10 = 260Hz. Then C = 1/ (2Pi x 4 x 260) = 150uF.
This keeps the effect on the crossover small, while keeping C to an acceptable size.
Old 5th June 2019, 07:45 PM   #7
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
You might solve it two ways, both valid.
1) add a capacitor calculated to be an extra pole added based on your current active crossover.
You now a next higher slope Xover or you might use one less in the active one to leave "everything the same"
A "grammar nazi" might complain "itīs not an active crossover any more but a mix of active and passive"
He may "technically" be right but anyway .... no big deal.
2) make the protection capacitor large enough to work 2 octaves below (my choice) or a decade below (almost same thing) so it does little if at all.
In any case, donīt overthink it.
Personally I donīt worry about any input signal problem but the feared blown power amp which applies brutal DC to very weak tweeter voice coil.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 8th June 2019, 03:15 AM   #8
Thanks everyone for your advice.
Old 8th June 2019, 06:51 AM   #9
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
You do realize that there already is a series cap as part of the crossover, which blocks DC and attenuates low frequencies reaching the tweeter?
So you are putting another one in series if you do this.
Then you have two choices:
a) make it much larger than the cap already there so as not to impact on the xover frequency, but that has no impact on the protection issue;
b) make it much smaller than the cap already there which tightens the protection but messes up the xover frequency.
The only way to avoid all this and keep the existing protection, including the DC blocking, is to do nothing.
A rare case where spending money would actually do either noting or do harm to your sound.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 10th June 2019, 01:16 AM   #10
That would be true of a passive crossover. I am running an active crossover an AudioControl Dm-810 processor. The crossover is done pre-amp so there is nothing between the amp and the tweeter to protect it from any failure that could possibly damage it.
Capacitor value for tweeter protection with active crossoverHide this!Advertise here!
Tweeter protection in active setup krassyg Multi-Way 30 9th January 2017 02:12 AM
Tweeter Protection Going Active ODougbo Multi-Way 5 13th November 2015 08:17 AM
Using MiniDSP with Capacitor for Tweeter Protection lucadelcarlo miniDSP 3 30th January 2014 09:08 PM
Protection capacitor for tweeter in active speaker oceanic30 Multi-Way 11 30th July 2007 02:15 PM
Tweeter protection for active speakers paulspencer Multi-Way 31 26th October 2005 08:40 AM
Copyright ©1999-2019 diyAudio
