Deaf Bonce AAB-7800.1D (soundigital 8000.1 evo I think)
Old 16th May 2019, 04:05 AM   #1
Crazylogix is offline Crazylogix  United States
Default Deaf Bonce AAB-7800.1D (soundigital 8000.1 evo I think)
I have a Deaf Bonce AAB-7800.1D which is supposed to be made by soundigital, it is a copy of the 8000.1 evo I think, It is supposed to be a full bridge amplifier (I was told). Its problem was when powered up it would instantly light up the clip indicator light. I was told the amp was mounted to the sub woofer box, so we opened it up and looked for some vibration damage. Found some, one of the output filter coils had snapped its leg. Removed the coil, matched the wire awg, and repaired. Reinstalled the coil and E6000ed it in. The amp would then power up just fine and play. Put it back in the heat sink and tested it lightly for a little bit, thinking that was all that was wrong with it (my mistake, should have tested it hard). buddy came to pick it up, I hooked it back up on the bench to show him it was working, played it lightly for a minute, and then it seemed to make a noise (not a pop, but a thump is more like it, maybe due to it being hooked to a sub). The clip light is now back on. GGGRRRR! Getting ready to take it back out of the case and check the big output filter caps, anyone work on one of these, the driver chips etc are defaced. And the PIC16F1828 chip is what turns on the clip indicator (from pin 13). Any help before we ship it out would be great! Thanks.
DMM - HP 1222A scope - Hakko FX888D - 50w Unger iron - Yihua 858D Hot Air - 65A power supply (modded dell server) - 1000w 4 ohm test load - test sub - My Youtube repair videos -> Crazylogix
Old 16th May 2019, 04:07 AM   #2
more pics
Deaf Bonce AAB-7800.1D (soundigital 8000.1 evo I think)Hide this!Advertise here!
ic4 lost in soundigital 8000.1 evo Rafawilson Car Audio 6 Yesterday 02:20 PM
Help for soundigital transistors maurosubito Car Audio 2 14th May 2018 09:07 AM
SounDigital SD8000.1D? ThyDntWntMusic Car Audio 1 11th January 2018 04:35 AM
Soundigital 8000.1D rca gnd brandes.cm Car Audio 0 24th March 2013 05:22 PM
Soundigital 8K brandes.cm Car Audio 36 5th January 2013 11:28 PM
Copyright ©1999-2019 diyAudio
