Dead CXA300.1
Dead CXA300.1
Old 20th May 2019, 06:04 AM   #21
zinoyracer is offline zinoyracer  United States
R105 is 5.0ohms but my leads test 0.3 so after correction itís 4.7 ohms
IC3
1-12
2-12
3-5.7
4-0
5-2.04
6-2.04
7-0
8-5.6
IC2
1-.85
2-3.36
3-.06
4-.04
5-1.39
6-3.6
7-0
8-4.94
9-2.04
10-2.04
11-4.93
12-11.84
13-4.94
14-4.94
15-1.97
16-1.46
Old 21st May 2019, 06:11 PM   #22
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
Based on the DC voltages, you have drive from IC3. If you have an oscope, take a look at IC2 pin 5-triangle wave, Pins 9&10-Drive and IC3 Pins 3 & 8-rectangular wave with 50% duty cycle.Use power ground for scope ground. Post screen shots.
Otherwise, replace R68 and mosfets. Check the gate resistors R117,118-33 ohm. Also, with everything in place with an ohmmeter measure between all three pins of the mosfets including output mosfets. If there are no shorted devices, power the amp and check the DC voltages around the IC2 & IC3 as you did before.
It's possible the amp is producing rails and there is a problem elsewhere.You will see the rail/DC voltages across the 2200uf/50v caps, black probe to power ground, C76,C78-positive rail, C77,C79-negative rail. Both should be ~35v? Not sure of absolute value.
Also check the =/- 17 volt rails. Q16-(-17v) Q18-(17v) and on either side of R10 & R14-10 ohm resistors.
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Dead CXA300.1Hide this!Advertise here!
Kicker CXA300.4 No power rhempz01 Car Audio 3 26th March 2019 07:36 PM
Kicker cxa300.4 audio jack problem amp 2 rhempz01 Car Audio 3 14th March 2019 01:32 AM
Kicker cxa300.1 help please jayjs730 Car Audio 3 10th February 2019 02:15 AM
Kicker CXA300.4 no audio troubleshooting help. rhempz01 Car Audio 19 4th November 2018 03:15 PM
Kicker CXA300-4 Won't power on. rhempz01 Car Audio 8 25th July 2018 07:08 PM
Copyright ©1999-2019 diyAudio
