JL 1000/1v2 rebuild
JL 1000/1v2 rebuild
Old 25th May 2019, 05:15 PM   #21
miniman82 is offline miniman82  United States
Is there anything you don’t know?
Gear I use: Tektronix 475 Oscilloscope, Lambda LA-200 Power Supply, Rat Shack DMM, 100w homebrew resistive dummy load, 20 Years Experience as a Navy Aviation Electrician
Old 27th May 2019, 02:33 PM   #22
So I got the new outputs from Mouser but figured I’d skip the 22.1’s since I have similar values around here. Tried 47r first, but the gate waveform looked sloppy and rounded to me (slow) and the FETs seemed to be getting a tad warm. So I tried 10r and it seems nice and sharp, good rise and fall times. Any reason I shouldn’t just go with10?
Old 2nd June 2019, 02:55 PM   #23
Got the amp back together and working, noticed 2 things.
1. The output inductors get pretty warm after playing for about a half hour, I don’t recall that happening with the lesser slash amps so I’m asking if it’s normal
2. The filter stages don’t seem to be working, I’ve read that some of the OPAMPs can lose power through the traces in the pre card but is there anything else that’s a common fault?
Need to spray the flaky switches out too, but other than that it’s made a pretty good recovery. Thanks for all the help!
Old 2nd June 2019, 07:12 PM   #24
Perry Babin is offline Perry Babin  United States
If an op-amp loses it's power source, it generally goes silent.
Don't seem to be working? In what way?
I don't know about the temperature of the inductors. Obviously, if the insulating tape is melting, that's bad but what's 'hot' to the touch, isn't necessarily hot to the component.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 2nd June 2019, 09:55 PM   #25
Thanks Perry,
It’s the Q, center freq, boost and subsonic that aren’t having any effect, though sound does make it through the amp. I guess the switches could still be to blame, I’ll clean and deoxit then see what happens.
Old 2nd June 2019, 10:50 PM   #26
The bass EQ switch defeats the boost circuit (and Q and frequency).
JL 1000/1v2 rebuildHide this!Advertise here!
Loudforce 1000.1 rebuild Chuchohfbass Car Audio 2 3rd January 2019 01:28 AM
Is this amp rebuild-able? chipper Car Audio 8 16th February 2013 05:19 AM
CJ PV-5 PS rebuild mmmalmberg Tubes / Valves 0 11th October 2012 12:49 AM
Would you rebuild this? Rockmore Tubes / Valves 2 25th December 2010 11:18 AM
DCM Time Frame 1000 rebuild help danclarkwcp Multi-Way 1 8th January 2006 05:01 AM
Copyright ©1999-2019 diyAudio
