JL 1000/1v2 rebuild
JL 1000/1v2 rebuild
Old 17th May 2019, 04:46 PM   #11
Perry Babin is offline Perry Babin  United States
That's the transistor used in the newer versions.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 17th May 2019, 06:06 PM   #12
miniman82 is offline miniman82  United States
Excellent, soldering shall commence this evening.
Gear I use: Tektronix 475 Oscilloscope, Lambda LA-200 Power Supply, Rat Shack DMM, 100w homebrew resistive dummy load, 20 Years Experience as a Navy Aviation Electrician
Old 21st May 2019, 04:38 PM   #13
Power supply works but now I have the low ohm light, somehow I smoked an output FET. The originals are NLA but Mouser stocks STP40NF20 which looks like a viable candidate, see anything wrong with it? Original was 45n20.
Old 21st May 2019, 05:04 PM   #14
The newer models use FDP52N20 FETs with 22.1 ohm gate resistors. I don't know if the others will work.
Old 21st May 2019, 05:13 PM   #15
Bonus, the 52n20’s are cheaper. Ordering now.
Old 21st May 2019, 05:16 PM   #16
Order the resistors if yours has something other than the 22.1.
Old 21st May 2019, 06:13 PM   #17
I’ll have to see what it has currently
Old 22nd May 2019, 10:32 AM   #18
Gates currently have 4.7Ω on them, I’ll get some 22’s.
Old 25th May 2019, 11:56 AM   #19
Almost forgot to ask, what’s the name for this soft material attached to the transistor clamps? Some of it got burned up when the power supply let go, so I need to source some to replace it.
Old 25th May 2019, 12:33 PM   #20
1466N12
McMaster-Carr
JL 1000/1v2 rebuildHide this!Advertise here!
Loudforce 1000.1 rebuild Chuchohfbass Car Audio 2 3rd January 2019 01:28 AM
Is this amp rebuild-able? chipper Car Audio 8 16th February 2013 05:19 AM
CJ PV-5 PS rebuild mmmalmberg Tubes / Valves 0 11th October 2012 12:49 AM
Would you rebuild this? Rockmore Tubes / Valves 2 25th December 2010 11:18 AM
DCM Time Frame 1000 rebuild help danclarkwcp Multi-Way 1 8th January 2006 05:01 AM
Copyright ©1999-2019 diyAudio
