Metrik MAB 901
Metrik MAB 901
Old 13th June 2019, 07:53 PM   #11
barber02 is offline barber02
I’m getting +51.6 and -51.7 on the using the primary ground.
Old 13th June 2019, 08:00 PM   #12
Perry Babin is offline Perry Babin  United States
OK. I was concerned that you may have had an intermittent primary to secondary transformer short. You may, but it could be intermittent. 50/62 is a huge difference and hard to have due to a mistake if you were measuring on the main rails.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 13th June 2019, 08:09 PM   #13
The voltages I stated earlier were taken from the center pins of the output mosfets grounded to the primary of the transformer.
Old 13th June 2019, 08:19 PM   #14
When I measure the center pin of the output mosfets grounded to the secondary side of the transformer the voltages are almost equal at about 56 vdc + and -
Old 14th June 2019, 09:21 PM   #15
Ok. So I pulled the rectifiers and the amp still comes on briefly and the stops oscillation and and never trips the protection LED. Then I decided to bring it up on low voltage and the power supply comes up happy and stays in oscillation. I started at 10 volts and slowly increased the volt and when the supply voltage hits about 12.6 volts the power supply stops oscillating. What gives?
David
Old 14th June 2019, 09:25 PM   #16
It's hard to say without a diagram. You need to start at the control IC. See which pin changes in voltage as it shuts down and follow the circuit back to see what's causing it.
Old 15th June 2019, 01:42 AM   #17
Bummer. This amp is eating my lunch. But, on the bright side, I’m learning.
David
Old 15th June 2019, 02:38 AM   #18
Ok. This is the drive wave coming off of pin 9 and 10 of the TL494 with 12.3 volts of input voltage. If I go higher than 12.5 volts then the chip shuts down. This drive wave doesn’t look healthy. It’s not turning on and off fast enough in my opinion. Pin 3 goes high when I raise the input voltage and shuts the chip down.
With the chip running at 12.3 volts pin 1 is sitting at 1.48 volts and pin 2 is at 3.43 volts. Pin three sitting at .077 volts.
When I raise the voltage above 12.5 volts then pin three goes high at 4.7 volts and pin 1 is at 1.77 volts and pin 2 is at 3.44 volts.
Old 15th June 2019, 02:42 AM   #19
This is the area around the TL494 chip.
Old 15th June 2019, 02:46 AM   #20
Switch to DC coupling. AC coupling should only be used under the rarest tests.
Are you using your probe set to 1x or to 10x?
Metrik MAB 901Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
